Hi there, I am having a fillet issue. Clearly this would be easier if the middle polysurface was round, but it is not. What is the best way to approach this to have a somewhat smooth and rounded edge? Thanks!
Evergreen fillet problem.3dm (13.6 MB)
Hi Courtney - something like this?
That is a lot of FilletSrf
on a thing like this - and you’ll get collisions to sort out, but I do not see a better way given what you have. I would look into SubD modeling in V7 - in the long run for this sort of thing I think you’ll be happier.
I am trying to fillet the flat edge. I left some space after the leaves to simplify it.
Thanks @pascal @Tom_P
Evergreen fillet problem.3dm (13.4 MB)
use the following command to find visually the smallest radius, biggest curvature in of the edge
_dupEdge
_curvatureGraph
_radius
something bigger then 0.65
_filletEdge has to be set to a radius smaller then that → 0.6 (or less)
and does the job here
something close to what you re searching ?
kind regards
tom
Evergreen fillet problem_tp.3dm (12.6 MB)
Yes exactly, thank you @Tom_P ! I have never used curvatureGraph before. I will have to try it!
Courtney
it is just to estimate the position, where the smallest radius is…
