I can not get any fillet attempt to work on the cutout top edges in the attached (WIP 9, windows) model. I would appreciate any help with this. I will accept alternative approaches too. If at all possible, I want the fillet at the apex of the curve to be as large as possible, and have it taper down to 1mm on the rest of the edges.
@Grant837 of don’t bother you too much you could attach the done file and a screen of the solution that could be useful to other user and eventually @menno could add it to the list of difficult fillet.
how do you expect a true arc fillet / a rolling ball should fillet / fix those none tangent details of the cut out ?
(green faces are local 1mm _filletSrf - Surfaces)
no way for a sphere rolling along to generate a continuous surface here ( the gabs between 2 green fillets )
YES! Thank you, the Pipe Trim Trick and Blend worked.
I used DupeEdge and filleted the curve corners .5mm before using pipe. For Blend I set the tolerance to .01 and used tangent on the top and position on the lower edge
