Fill parameters in Revit looking in/out shape
Hie,
I am trying fill parameters in Revit using if the object is in/out a shape. The problema is that the component give me a mistake. Could you help me?
Regards.
You’ll need to get the Geometry from the Revit Element the using Element Geometry Component.
This will give you a Brep, although i’m not exactly sure what Type of object the Shape input requires. Is that component from a plugin?
Thanks so much @Japhy . That component appears in Grasshopper standar. In Surface/analysis tab.
Regards
Hie,
With Japhy´s help i could do the topic of “in/out shape”. Now the problem is that i have 100 elements but when i use it for the “shape in Brep” component i have 1477. I don´t know how i can relation the 100 elements with the booleans result of 1477.
Regards
Test.gh (12.4 KB)
You could do a union bounding box of the elements (use the elements plane) so that only 1 is being tested.
Thanks. Ok, i am going to try it.
Regards.
Hie,
I finish it and i show the way.If someone wants to improve it…
Regards
Below is my recommendation from what I am seeing in the image
Thanks so much.
