Fill in Terrain Gap
Hey there,
I’ve been searching for the solution for this problem for a long time now. I want to fill in a gap with surface between these surfaces (roads) and an outline of the building’s base as shown on an attached image. How to do this? Really interesting to see.
Thanks in advance.
Gap_Question.3dm (316.9 KB)
have you tried the _Patch command on Rhino WIP? for me it did wonders so far
I have not. I’ve seen a few posts about it and it really seems like a possible solution for this problem, but I do not have Rhino WIP version. Are there any other ways in the stable version?
none that I know of
what I do is that I copy just the necessary elements to create the surface in a separate Rhino WIP file, create the surface, then copy that back into the main R8 file
this should also work with patch in rh8
i bit of bricolage… depending on what you re after - this might fit:
make sure the outer edge give a continuous curve.
use
_Split (Isocurve)
_mergeEdge
(or _UntrimAll)
you have to trim the inner hole in a second step.
if precision does not match your requirements - you can still add some transitions as stripes of _blendSrf …even more bricolage ;-D
