Any suggestions on how to solve this? Model before fileting, and after. I would have thought Rhino would have been able to transition the difficult area.The red outlines the voids.
can you post the model?
Click_Stick_end_2v.3dm (194.0 KB)
I’m seeing same behaviour here… and I think it’s because your two surfaces go tangent at the center of the part-
Can I share this with our developers?
here is a workaround-
I don’t know what you mean by Boolean after the fillet. Which boolean command?
fillet the u shaped part 1st, and then the puck it connects to-
then boolean union the two parts together.
Oh, I get it. However, that requires fore thought of all the parts and how they will eventually look together. I was working more organically. Model the object and add fillets as finishing. As I would have done it building with my hands. I guess I may have shift how I work. That said, SolidWorks was able to fillet after modeling with one click.
thanks for your help.
