FileSettings.FileLockingEnabled Not Working
I am trying to disable File Locking in our Skin for Rhino. After setting these properties to false, they are still true.
What else should I be doing instead to disable this behavior?
FileSettings.FileLockingOpenWarning = false;
FileSettings.FileLockingEnabled = false;
Hi @jstevenson,
Are you calling this from your skin assembly or from your plug-in? If the plug-in, when and where are you calling this?
Just trying to figure out how to repeat - thanks.
– Dale
I’m calling from within the Skin Assembly OnEndLoadAtStartPlugins() method.
I’ve tried adding logic to execute the setting on Initialized also to no avail:
RhinoApp.Initialized += RhinoAppOnInitialized;
Any thoughts?
Hi @jstevenson,
Looks like this is no fault of yours.
https://mcneel.myjetbrains.com/youtrack/issue/RH-47360
– Dale
I was able to change the values from within the Plugin OnLoad method, just not from within our Skin DLL. Thank you sir!
