all my obj files that are bellow 3mb display fine after upload. The files above 3mb, display blank after upload. Is there a limit set?
There is a 50mb limit on file imports for Pro accounts. However, there is also another more technical limit for the number of faces of the meshes in the obj file (64000 faces). The mesh gets reduced above that threshold, which sometimes leads to errors. Can you check the number of faces as well?
In case your file complies with the limits, could you send it to me so I can test? Do you get this error when trying to upload local files or when linking to an external URL (or both)?
Seems like this could be the issue. This is one of the files.battista dx misura 33.obj.zip (1.6 MB)
