I’m trying to export Rhino geometry to .dxf on the server via an RH_OUT Text component.
The only way I’ve found to do that is to export to a file and then read it back in. I’m using a C# script that works perfectly in the Rhino app on the server to write to C:\Users\RhinoComputeUser\Documents.
However, Rhino.compute apparently does not have access to this directory.
Where can I export a file and then read it? (Or is there a better way to do this in memory?)
Thanks,
Bill
Here is the error message:
FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)\r\n at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)\r\n at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost)\r\n at System.IO.File.InternalReadAllText(String path, Encoding encoding, Boolean checkHost)\r\n at Script_Instance.RunScript(List`1 Geo, List`1 Layers, String TempFilename, Boolean DeleteTempFile, Object& DxfTxt) in c:\\Users\\RhinoComputeUser\\AppData\\Local\\Temp\\ypvrftiz.0.cs:line 97\r\n at Script_Instance.InvokeRunScript(IGH_Component owner, Object rhinoDocument, Int32 iteration, List`1 inputs, IGH_DataAccess DA) in c:\\Users\\RhinoComputeUser\\AppData\\Local\\Temp\\ypvrftiz.0.cs:line 163\r\n at ScriptComponents.Component_AbstractScript.SolveInstance(IGH_DataAccess access)","Properties":{"Port":"6002"}}
{"Timestamp":"2024-08-04T18:48:52.0786546+00:00","Level":"Error","MessageTemplate":"Could not find file 'C:\\Users\\RhinoComputeUser\\Documents\\D17817851.dxf'. (line: 0): component \"C# Script\" (f5cfc116-d7de-46b2-a020-cca5231e9904)","RenderedMessage":"Could not find file 'C:\\Users\\RhinoComputeUser\\Documents\\D17817851.dxf'. (line: 0): component \"C# Script\" (f5cfc116-d7de-46b2-a020-cca5231e9904)","Properties":{"Port":"6002"}}
Here is the C# script that is doing the file operations.
private void RunScript(List<GeometryBase> Geo, List<string> Layers, string TempFilename, bool DeleteTempFile, ref object DxfTxt)
if (Geo.Count != Layers.Count) {
DxfTxt = "Error in GH model"; // the lists of Geo items and Layers must match up exactly
return;
RhinoDoc doc = RhinoDoc.Create(null);
// static objects used for each item, with appropriate mods
Rhino.DocObjects.Layer rhinoLayer = new Rhino.DocObjects.Layer(); // layer info is copied when added, so use this one over and over
Rhino.DocObjects.ObjectAttributes attributes = new Rhino.DocObjects.ObjectAttributes(); // same for assignment to layer
// loop over Geo and Layers in sync
for (int i = 0; i < Geo.Count; i++) {
var item = Geo[i];
var layerName = Layers[i];
int layerIndex;
// create/add the layer
Rhino.DocObjects.Layer layer = doc.Layers.FindName(layerName);
if (layer != null) {
layerIndex = layer.Index;
else{
// add it if it doesn't exist
rhinoLayer.Name = layerName;
layerIndex = doc.Layers.Add(rhinoLayer);
attributes.LayerIndex = layerIndex;
// add the geo item with its layer and then select it
System.Guid guid = doc.Objects.Add(item, attributes);
doc.Objects.Select(guid);
// export to .dxf
Rhino.RhinoApp.RunScript(String.Format("-Export {0} Scheme Fusion EnterEnd", TempFilename), false);
// read the file back into GH
DxfTxt = File.ReadAllText(TempFilename);
// clean up
doc.Dispose();
if (DeleteTempFile) {
File.Delete(TempFilename);
