My file is wayyyyy too heavy, Idk why, Idk how to fix it, I need to make it way lighter in order to continue working with it, Idk what I did to make it so heavy but its freezing my laptop. HELPPP PLS!!!.
Each triangle is a polysurface, maybe thats the reason its so heavy, if thats the case how can I make it a clean model?
The facets appear to be planar, but I did not check them all. Merging the coplanar faces in each facet will help, since Rhino won’t try to mesh each surface within facet for display (there are thousands of surfaces in each facet). Turning the meshing all the way down for the display can also help.
Depending on the intended use, there might be other considerations. Note that some surfaces are meshes, not polysurfaces, so that could be an issue depending on how you intend to modify these.
