File Path and Read File compatibility
I wanted to use the components File Path and Read File for my Shapediver Configurator as a way of quickly adjusting price estimation with a CSV. I understand the Shapediver doesn’t allow for the component Read File to be used, but is there a work around, or equivalent component that is compatible with Shapdiver? I just need it to read a csv hosted either locally or on a web server.
Thanks!
You can do precisely what you need using the Import Text component, which allows csv as input format.
