File not found: Deform_analysis.georhino.txt
Hi! I’ve been trying to run Kiwi3d for structural analysis of a shell, and I received the following error: 1.Deform_analysis.georhino.txt
Furthermore, when I hit run the console starts but no code is shown to be running, and then it closes
Kiwi_analysis.gh (13.7 KB)
thanks for the help.
Hey,
did you move the files after the installation? You can check the file path of TeDAsharp (comes with Kiwi) in the plugin manager of Rhino. There should be the plugin file + carat.exe in the same folder.
Furthermore, you can check which files are generated for the analysis. There should Deform_analayis.txt, xxx.georhino.txt, xxx.out.post and out.log next to your GH-file.
Thanks! that worked, for some reason grasshopper couldn’t find the files but when I moved the folder to the desktop it managed.
