File Management With Multiple Details
I am looking for a general approach for the following problem.
I have ship plans. Generally there is one plan per deck. Those plans have a lot of different layers for different types of detail (e.g., Decks, Bulkheads Doors, Ladders, Machinery). They also include a lot of research information, such as measurements and notes.
I need to be able to output these in different formats. For illustration, lets say book and printed plan. For a book, I need to include callouts, the plans need to be in smaller scale. The text needs to be larger and I have to match the plan font to the book font. The plans need to be split to fit on a book spread.
A compartment name, for example, needs to be different text from a printed plan. The font frequently needs to be different and the text needs to be positioned and line broken differently, so I cannot just use Rhino’s automatic scaling. E.g. when a plan has to be split across book spreads, the text has to be either in one spread or another.
In some plans I want to include measurements. In others I do not want measurements.
Next level of complexity:
From a base set of plans, I want to be able to depict the different ships of the same class and have different parts I can include that are specific for each ship.
At present I have been doing this using layers and separate sets of layouts. The number of layers is getting staggering and it is hard to manage what goes into a specific plan.
I was wondering if anyone has come up with a good approach to dealing with this issue?
Okay this sounds like a lot of issues…so you don’t just want different layers on/off but different text/dimension styles, line styles and actually modified dimension locations sometimes? And keep track of parts? And there’s probably more stuff you’d want to do… It actually does sound like something I did back in the 00’s where I had an elaborate layout with tweaks for print vs screen.
The most elaborate stuff I do these days as far as managing product data and various sorts of documentation involves InDesign, Rhino, and a database all glued together with a bunch of scripts.
Yes, it’s a lot of different issues rolled up into one. I was just wondering what approaches people have taken who have encountered similar issues. There’s not going to be a silver bullet.
I mean all the swapping styles/visibility and even identifying annotations that need to be moved out of the way of a page split sounds eminently scriptable, but how that actually translates into a workflow that actually helps save time requires looking at the whole process.
I was wondering if blocks might be used and reference from common files, for example.
Sure, in general, that’s what blocks are for, but note that trying to use blocks as any sort of ‘assembly management’ thing is doomed. Ask me how I know.
