File keeps freezing
I added some complex hatch shapes to my file and now rhino file keeps freezing despite it being only a 0.4 GB sized file. I am working with files 10 GB that freeze a lot less. How can i fix this? thanks
what exactly?
stop what is a small file from freezing - filles almost 10x it’s size don’t freeze on my laptop. Something is wrong with the file…?
Please post the file and your systeminfo (run Systeminfo command in Rhino), Thanks
hi, the file contains confidential work atm…
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18122, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
License type: Educational Lab License, build 2024-07-12
License details: Cloud Zoo
Apple macOS Version 14.5 (Build 23F79) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro16,1
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (8 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
GPU Vendor: AMD
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/fahadzafarjanjua/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Corgi/0.6.3.0/Corgi.rhp “Corgi” 0.6.3.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.9.24194.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.9.24194.18122
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.9.24194.18122
does that info help?
It does, thank you.
There could be particulars in the file that would be helpful to know as well (the issue stated is seemingly file dependent), such as the number of hatches in the document as well as clipping planes etc.
https://www.rhino3d.com/upload
i’ve uploaded it, thanks.
Thanks for the file, we are still doing some testing, here is the initial take…
Hiding these extra objects to the Plan North helps, over 278550 curves. Moving these temporary work geometries to a new file via export selected is advised. This appears to be where the main slowdown is happening (curve processing)
There are a few bad objects in the file (SelBadObjects)
Fyi, the detail on these trees seems rather high for what they actually providing. These are considerations when trying to make larger projects efficient as possible. Do you know what software these were imported from?
Unfortunately I don’t but it was after turning these into hatches, that the issue began. What can I do? Thanks
You could use the rebuild command to rebuild the lines and preserve end tangents
thanks everyone
