back in 2016 I asked about having a fileinfo command and Pascal cooked something up. Well I looked back in this forum and the script is not linked up and it is not working for me now. Anyway you could repost or post a version that works with Rhino 6. Thanks!
file info like the _What command?
Hello - this is what I have -
FileInfo.rvb (6.9 KB)
Drag and drop to add
FileInfo
HowMany
(selected)
HowManyScene
What command is not as concise as file info. How do you load scripts in rhino6? I donât see it in the Properties.
Hello - drag and drop the rvb file from your disk onto Rhinoâs window. Then you can type any of those three aliases as commands.
Did not work. Says unknown command _Loadscript. I believe I saw yesterday a command saying something to the effect unable to load scripts. It just appeared out of the blue.
Hello - open Options > Plug-ins page and check to see if the RhinoScript plug-in is enabled:
if not, check the box, then exit options and try the drag and drop again.
I turned RhinoScript back on. However now I get this when I try to use Fileinfo:
"Unable to load RhinoScript.rhp plug-in. Dependent DLL is out of date.
Hello - can you please run SystemInfo
in Rhino and post the results?
Rhino 6 SR14 2019-4-28 (Rhino 6, 6.14.19118.15561, Git hash:master @ 8f0a84997c310a7ec1a42cf2704da8daa33e3e21)
License type: Commercial, build 2019-04-28
License details: Cloud Zoo. In use by: Intuitionusa ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DELLBIGDADDY
Non-hybrid graphics.
Primary display and OpenGL: Radeon ⢠RX 580 Graphics (AMD) Memory: 8GB, Driver date: 1-18-2018 (M-D-Y). OpenGL Ver: 4.5.13506 Compatibility Profile Context 23.20.15016.15
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 1-18-2018
Driver Version: 23.20.15016.15
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp âCommandsâ 6.14.19118.15561
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp âBongo 2.0â
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2018.2.5.819\ColorPicker.rhp âColorPickerâ
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp âAnimationToolsâ
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 6.14.19118.15561
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.6.14.669\PanelingTools.rhp âPanelingToolsâ
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 6.14.19118.15561
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp âSimLab PDF Exporterâ
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 6.14.19118.15561
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp âV-Ray for Rhinoâ
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp âDisplacementâ
Hello - please try:
Close all Rhinos.
Open Windows start menu > âAdd or remove programsâ.
Find Rhino 6, click on it and choose âModifyâ then âRepairâ.
Any better?
That did not get it. This may help. I just over the weekend installed the WIP rhino7. Also, I recall just updating Rhino 6.
Everytime I start Rhino6 up it says âmore or lessâ that it canât load rhino script up.
Hi @intuitionusa and @pascal
Did you find a fix already?
Iâm having a similar issue with rhinoscript not loading
When I try to load the plugin from the options list:
Tried to repair Rhino but that did not help
Rhino 6 SR15 2019-5-7 (Rhino 6, 6.15.19127.12061, Git hash:master @ 1ad7f43a70c96f327e9efba4674dfdbcaabdf4fa)
License type: Commercial, build 2019-05-07
License details: Cloud Zoo. In use by: Willem Derks ()
Machine name: WD10
Hybrid graphics system.
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-17-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 3-17-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 419.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2019
Driver Version: 25.21.14.1967
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp "Commands" 6.15.19127.12061
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Iris (1cd9c8f5-c901-426c-8e80-d6a2e2b18bba)\1.0.6911.20081\Iris.WinR6.rhp "Iris" 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp "RPC"
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp "Rhino Render"
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 6.15.19127.12061
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 6.15.19127.12061
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp "RhinoCycles" 6.15.19127.12061
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 6.15.19127.12061
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp "Displacement"
C:\Users\Willem\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\rhino-render-next\0.0.2\RhinoRenderNext.rhp "Rhino Render Next" 0.0.2.0
-Willem
Hi Willem - hmmm - I guess youâre also using V7/WIP, right?
Hi Pascal,
thanks for the reply
Yes I have it installed,
However I just tested a script from Dale for a maybe related item and that worked
I checked the rhinoscript plugin and that was loaded nowâŚ
I could be something else is happening or it just fixed itself because of a couple of restarts.
I report back if I have it happen again
-Willem
