File freezes on startup
I have a file that was working fine and seemingly saved properly. Now as I attempt to open it grasshopper freezes and becomes nonresponsive. I also tried to open previous autosaves of the file and they also have the same issue.
Smooth Node Generator.gh (54.0 KB)
Hi Brandon -
You can launch Grasshopper, disable the solver and then open that file.
In a quick test, I then disabled the C# component and enabled the solver again. Your input curves are not internalized, and, of course, component downstream from the C# component aren’t doing anything, but that should give you a starting point to start trouble-shooting the issue.
