File batch-processing?
Hi, i want to convert lwo objekt into rhino format. It is possible to select many objekts for batch processing. It must be import a file, rotate an axis, change the units into meters ans save it as a rhino file from the active window rendered perspektive.
In the future i want to switch my object-library from Lightwave to Rhino.
Thanks
