Is there a way to attached a file (for e.g. pdf) to geometry so I can download it if I share the Rhino model?
Thank you
Hello- use the Hyperlink
command for this.
Thank you @pascal ,
I know hyperlink command, but Is related to url or web instead It woud be useful to attached physically a generic file able to be exported with the 3d model.
Thank you again
Hello- that is all I can suggest that might help - but I don’t fully understand what you are after. Linked blocks might help, but you still need the linked file.
Thank you @pascal,
I mean a sort of repository nested into geometry. So when you transfer 3d model the files attached travel with it and when you receive the model you receive the files attached as well. As an example the files could be zip, pdf, world, xls an so on…
Thank you again.
