Fibonacci pattern with attractor
This is Paul Gooship’s picture
For me it is more like Rheotomic picture
If you want simple Fibonacci look, use that. It comes from Modelab Primer
Quite simple to replicate, use Daniel Piker Rheotomic script with square, then search the intersection of curves, then group points that are too near. Then voronoi, then scale Voronoi cells.
It is funny you put that, I had the same idea. Yes its uses Voronoi but it is quite interesting that it gives some less classical look. It changes from all the broken bones support question !
I am a total noob when it comes to all these kinds of patterns you guys use in architecture and design, in my field you rarely see such stuff. And so this message popped up when I tried to re-create your algorithm above. :smiley:
Quite funny you didn’t use often and it appeared
Also if you don’t need it Voronoi can be useful to solve other problem, like Medial Axis and many others problems … It is as useful as Delaunay triangulation (its dual).
Yes, a while ago I read a lot about the theory the history, still not so applicable in shipbuilding I think (perhaps only the interior design).
For sure, not so applicable
http://www.yankodesign.com/2011/04/15/yacht-for-entertaining/
That ship would be total waste of money.
Indeed. Only this ultra kitsch “proposal” is maybe (?) worst.
That is a waste of fuel :smiley:
I wonder how will maneuver this thing when exposed on high wind speed.
Looking for a dislike button
Nice pattern! but what I was searching is a pattern that is characterized preferably by same shape (like circle, ellipse, rhombus) etc radial.
Hello Alessia @etia.1, are you answering to me?
If so you were not clear. I gave you the way of doing the image you post as an example. So what is your main goal ? Draw something give the input you have … There are an infinity of patterns, so be more clear.
thanks, do you know also where I can find this script?
Not on my PC. I can post the script I have done but it is just 6 components so it is not hard to reproduce. First download rheotomic definition from Daniel Piker then add the others components.
thanks, no worries. It’s just that I am a beginner in Grasshopper, if you could post it later on, would be nice!
thanks again
Rheotomic Surfaces tool
by Daniel Piker 23/11/09
-updated 19/02/12
Distributed under the Creative Commons Attribution-ShareAlike 3.0 Unported license (CC BY-SA 3.0).
http://creativecommons.org/licenses/by-sa/3.0/
You are free to use this for commercial and non-commercial purposes, to adapt and build upon it, and redistribute it (under the same license), provided attribution is given to the original author. Please include a copy of this text with any distribution of derivative works.
With Square
WIth Diagonal 1 and 2
Rheotomic_Surfaces_Paul_Goodship_Like.gh (23.4 KB)
here a simple Fibonacci
fibonnacci_spiral_LD.gh (15.4 KB)
Thanks for your reply, I am really interest in the last image that you share (the one with different rose:
I try to re-write your script, but it does not work in my case, it gives me an error at the end, and I can see only one rose.
rose pattern.gh (7.2 KB)
thanks again
No need to recreate, the script was included ! You were mistaken by the vector placement.
Right click on vector component, then place the vector, they will move the points so you will have many copies.
