Hi there,
I’m still learning grasshopper, taking it day by day.
As of current, i’m looking for a way to replicate the fence wire pattern on grasshopper (reference image provided), which i can then apply on surfaces or extrusions. Any sort of help to start with will be much appreciated. Thank You!
Quan_Li
(Quan Li)
June 27, 2026, 12:46am
2
This post is really helpful for asking the good question, therefore learn fast with less pain.
Help Us Help You - Grasshopper - McNeel Forum
Is there a reason that you would not use a texture map with alpha for this? Real geometry will be very resource intensive.
T_Reischl
(T Reischl)
June 28, 2026, 3:21pm
4
An STL file contains only geometry —specifically, a list of triangles that define the surface of the object. It contains no information about:
Colors
Texture maps
UV coordinates
Materials
Bump maps
Normal maps
Displacement maps
So if you take a smooth cylinder in Rhino, apply a wood grain texture to it, and export it as STL, the STL will still be a perfectly smooth cylinder.
The important distinction
There are two ways a texture can affect a model:
1. Visual texture (texture map)
JPEG, PNG, HDRI, etc.
Makes the object look rough.
No actual geometry changes.
Does not export to STL.
2. Geometric texture (displacement)
The software actually pushes vertices in and out.
The mesh becomes physically bumpy.
This does export to STL , because the bumps are now real triangles.
In Rhino
Suppose you have a carved oak texture.
If you simply assign the texture in the material editor:
Material
…it only affects rendering.
If instead you use something like:
Heightfield
Displacement
Mesh Displacement
ApplyDisplacement (depending on workflow)
the mesh is physically altered.
Then when you export the STL, every little ridge becomes triangles.
dfytz1
June 29, 2026, 7:41am
5
I would recommend researching some weaving algorithms
Hi again!
I made some progress today, but I’m not quite there yet and could use some input as to how to proceed.
I managed to achive the “knot” along the middle of each edge:
[top view progress]
But now I need to connect the lines in some way and I’m having some trouble sorting them in correct lists. The goal is something like this:
[photoshopped]
Perhaps a better idea would be do to join the edges and work with them instead of working on each edge individually, I tried using the warpwef…
to adapt to your case.
Also i would keep it as a curve or a mesh with one face, so it stays lightweight
Yea, this was my concern as to why i couldn’t use a texture map.
