I’ve created a very simple fence from a line and a semicircle. I see errors in the 3d creation, in the rendering too.
Thanks,
Roy
Fence issue.3dm (6.2 MB)
Thanks,
Roy
Hi @lopez,
This seems to be a problem with the Rhino mesher as if you explode the railing, the rail geometry is correct, but the mesh is not correctly calculated. You can fix it by increasing the mesh precision in the Rhino options:
After modifying the mesh settings, run vaUpdate on the railing to rebuilt it.
Regards,
Enric
Yes, perfect!
It’s possible to modify the mesh setting only for the fence and not for the entire document?
Hi @lopez,
Sure, here you can change the mesh settings for an specific object:
Remeber to run vaUpdate command after changind the mesh settings.
Regards,
Enric
