FEM-Design question, how to set up Wire material
Hello members,
Do someone have experience to work with FEM-Design plugin,
Do someone know how to set up wire material,
Thanks to all for your attention.
Connect the Reinforcement Material to the Material input and use, for example, list item to select the material you want to use. You can also use the Material.GetMaterialByName|Index.
Diameter must be in meters.
