jeremy5
(Jeremy)
1
Hopefully this is just because we are mid-journey with the text improvements. But at the moment we have an icon:
called a Text object, but it produces curves, surfaces or solids.
And a menu item:
called a Text Block, which produces a Text object.
pascal
(Pascal Golay)
2
Hi Jeremy - TextObject
is not annotation text, it is text-shaped curves, surfaces or extrusions.
jeremy5
(Jeremy)
3
Hi @pascal,
Yes, understood. Just pointing out the confusing crossover of the terminology. Good to get this aspect tidied up.
Jeremy
pascal
(Pascal Golay)
4
Hi Jeremy - but these are different… the command run by the ‘text Block’ menu entry is Text
, not TextObject
. Am I being dense?
jeremy5
(Jeremy)
5
The command Text creates a Text object, according to Properties.
While the command TextObject creates things that are not Text objects. This is the bit I find to involve confused nomenclature.
