As a passionate and long-time user of both Rhino and Grasshopper, I truly appreciate the incredible work you do to constantly improve our design workflows. With the exciting UI updates rolling out, I would love to share six structured proposals aimed at further unifying and streamlining the interface to enhance user productivity.
Proposal 1: Layout Panel Enhancements
“Change Object Layer” Shortcut: Add a quick icon directly next to each layer in the Layout panel to eliminate switching back and forth between panels.
Dynamic Object Counter: Integrate an object counter next to the layer color indicator with a toggle for “Total” or “Detailed” counts.
Proposal 2: Seamless Grasshopper Integration
Grasshopper Workspace Mode: Introduce a dedicated mode where the Grasshopper canvas behaves as a native, dockable viewport.
Modernized RCP: Bring back the Remote Control Panel with a modern UI matching the Rhino 9 Command Prompt style.
Context-Aware Toolbars: Automatically switch active toolbars based on whether the cursor is in a Rhino viewport or the Grasshopper canvas.
Adaptive Icon Display: Show only frequently used icons by default, with advanced/lesser-used commands accessible via dropdowns to reduce visual clutter.
Instant Switching: Provide immediate access to these presets via buttons adjacent to the main menus.
Proposal 5: Visual Command-Keyboard Overlay
On-Demand Alias Map: Implement an overlay that appears when holding the middle-mouse button, displaying a virtual keyboard where keys are mapped to custom aliases.
Workflow Benefit: This eliminates the need for modifier keys and provides a visual reference for custom shortcuts, significantly boosting modeling speed.
Proposal 6: Scrollable Input Fields
Mouse-Wheel Adjustment: Enable the mouse scroll-wheel to increment/decrement values in numerical input fields and cycle through options in dropdown menus. This allows for fast “on-the-fly” adjustments without manual typing.
Thank you for your time, openness to community feedback, and dedication to making Rhino the best design tool in the world. I truly hope to see these workflows considered for future updates!
RH-56295 Provide layer column for selecting layer object or change object layers
Three of these are at least partly available today: the Change Object Layer button on the Layers panel, the Remote Control Panel (the Grasshopper panel), and scroll-wheel editing in spinner fields. Worth a look in a current build. On scroll-wheel specifically, RH-52437 is useful background on why broader support needs care.
The Grasshopper RCP has not had any updates in over a decade. There are other options tho.
I recently added dockable panel support to DKUI, and with CSS control over the appearance of all the UI elements you can match the style to “anything” really:
I’ve wanted this feature since I started using Grasshopper. The worst thing in terms of UI/UX with Grasshopper is that it is not adhering to the ctrl+tab rule. In windows you use alt+tab to switch between applications and ctrl+tab to switch between windows/tabs within the current application. In Rhino ctrl+tab switches viewports. That makes sense though transforming the viewports to some kind of tab logic would mage more sense. Either beeing able to display Grasshopper in a Rhino viewport or tab would make ctrl+tab workflow possible for RH+GH.
Obviously this is too late for RH9 but naturally users would expect some groundbreaking changes in a version 10, right? Rhino X maybe?
I’m so glad to hear that there is someone at McNeel open to new UI/UX ideas. If there is any point in time for a software spanning multiple decades and version numbers, 10 is obviously the one where you want to make bigger changes.
Btw, “responsivenes” is a word that I mentioned a few times already, throughout different threads in relation to Rhinos UI. Specifically I meant the lack thereof. Please take this into consideration as well.
Really good that someone took time to lay out those proposals very well and a very good sign that the team actually made youtrack items from those.
