Hans, can you post an example of ConnectSrf? Behavior has changed in SR7 I think… The change is that if the input surfaces intersect, the trimming should pay attention to the pick location- the picked part is kept,
The blue surface behaves as expected, but on the green one it only trims away the smaller part (SR7).
If it keeps the area that’s picked now (which makes more sense because often picking an edge is ambiguous), then the language in the command prompt needs to be changed.
Hi Hans- here, if I click on any edges on one side of the intersection, the clicked part is always kept but I see the prompt problem… not sure how to solve that, off hand…
