[Feature Request]
Worksession Instance Transform
Decoupling Model Space from Assembly Space
(Like XREF / Instances)
Problem
Worksessions assume all files are already aligned in world space.
That forces:
Modeling far from origin (bad precision)
Manual pre-alignment (fragile)
Editing source files just to reposition (breaks modularity)
What’s Missing
A transform layer per attached file
Right now:
No position -
No rotation -
No scale
Worksessions = reference only, no placement
Proposal
Each attached .3dm gets a non-destructive transform:
Position (X,Y,Z)
Rotation
Scale
Stored in the Worksession .rws , and not in the .3dm file.
Why
All modern systems do this:
AutoCAD → XREF insertion
Autodesk Revit → linked models
Blender → linked collections
Unity / Unreal Engine → transforms
Model locally. Assemble globally.
Why Not Blocks?
Blocks work, but:
Not file-level
Add hierarchy overhead
Not ideal for large multi-file workflows
Impact
Keep the active open geometry near the origin
True modular workflow
Clean collaboration
Massive improvement for large projects
Simple UI
Right-click file → Edit Transform…
Simple Implementation
Important: Must also remember previous transforms
Cons
FBX can’t export .rws transforms properties
Closing
This is a small feature, simple to implement with a huge impact.
Worksessions need placement, not just visibility.
