I know that when you create a viewport in paper space, you can choose to turn off layer visibility for that viewport, while having it remain visible in all other viewports.
I would love to see the ability to turn the visibility off for the entire file, yet allowing it to be turned on for a specific viewport.
It would make geometry dense models significantly easier to navigate.
The current work flow is accessed from the Layers panel on the Detail visibility “light bulb”.
See the steps here.
In addition to this, you can set a layer’s to “New Detail On” to OFF, and when you make a new detail that layer will automatically be OFF in that detail. This does not help with existing details. Use the above link for those steps.
Let us know if this works for you.
Sincerely,
Mary Ann Fugier
