Nothin more to add. A dearly missed functionality.
Trim and Split work for me in Perspective viewports in V7, V8 and V9 Beta. I did not test in earlier versions.
@Lagom What is not working for you?
Never had problem with trim and split BUT I understand you should be aware of all the possibile complication.
Trim works, mainly, by PROJECT along the vertical direction of the Cplane
Trim project according to the Curve plane if possible
Trim has the capability to use the APPARENT INTERSECTION (really dangerous if you aren’t aware)
Trim does PULL the curve if the curve is a 3D curve
This are some examples
20260922_Trim.3dm (438.0 KB)
To me is a very powerfull tool and I like the way it works.
@Lagom where you find problems?
It’s not about whether it’s technically working or not working per se. It’s about working from the chosen Perspective view. It apparently only works on the base of the currently set construction plane, but not from the current view like in Alias, etc.
Project, however, does work from the Perspective view, so Trim and Split should do, too.
So you want an option to determine “apparent intersections” in Trim and Split using the view direction, similar to the options in Project.
The result would be the same as using Project with the Direction=View option to project the cutting objects onto the objects to be trimmed or split, and then using Trim or Split with the projections as the cutting objects.
That would be useful.
The problem is that one cannot Trim from the chosen view in Perspective, like in Alias, etc. Very useful for common Y-fillet and K-fillet modelling techiques, for example, or cutting desired highlight or crease lines into surfaces from important viewing angles, to then restructure the surfaces accordingly.
This can be simplified: You choose the desired viewing angle, then you must Project, and then you can Trim.
I may understand but I would not feel confortable to trim just from the view.
I would always create a construction plane, tangent to the surface or from the view, and then create the curve I need.
May the _OnSrf osnap would help what you need? Using it you can create the curve from any view directly on the surface.
Yes, that’s the requested feature. If one can Project from any view, why not directly Trim from any view?
Example below: Common Y-fillet modelling technique. First, set the projection to parallel. From experience, you know suitable viewing angles for how the two “cut-and-insert” curves shall trim the two surfaces in question, but you also may want to quickly try out two or three slightly different viewing angles.
