It would be fantastic if VisualARQ added the ability to dynamically hatch surfaces, to be shown in ‘Hidden’ display mode the way it currently does with sections.
That would allow a Revit-like easy creation of drawings that could be printed in vector with an indication of materials/surfaces.
My current workaround is to add hatches/fills as separate objects using grasshopper but it would be amazing if ‘surface hatch’ was a property in the “section attributes” tab (even though strictly speaking, this would work with or without a section).
Ideally, there would also be a switch to turn this feature on and off, the same way you can turn on an off the line thickness display.
Does anyone else have some good workarounds for this?
