Feature request - sub object attribute user text visibility
I would like the ability to see the attribute user text for sub objects when selected.
The video example has a polyline with user text, if i select 1 line segment I’m unable to view the user text from the properties panel.
A more practical example would be a block made with clipping drawing of multiple polysurfaces. I would have to explode the block (break the link) to view each objects user text.
@rajaa with block instances, you can enter into the block and see the subobject attributes. Is there a way to do the same in a section drawing?
