Would be very useful. As the curvature graph shows where it is, maybe some code could pull it out for snapping to.
Would quad osnap works?
While trying to split a surface at its inflection(s), no snapping mode snaps to it(them).
so in Alias, you can extract those green inflection curves? (I deliberately wrecked that surface so that they are not isocurves)
for curves:
it should be straight forward to do a _extractInflectionPoints command as the functionality is there already:
Thankfully, you can extract just about anything from analytical tools to generate curves from that.
I found a workaround: You ExtractIsocurve the surface boundary or any internal isocurve. You switch on CurvatureGraph. You ExtractCurvatureGraph. You Trim the extracted surface boundary or internal isocurve with the extracted curvature graph curve. You have the inflection points : )
Now please turn that into an Osnap feature ; )
