It would be a good feature to have for the next update if the Section Indicator behaved a bit more professionally.
What I mean instead of just a continuous line, the way it should be implemented is to have it according to the following sketch. Red is current, green is what im proposing.
Section line should break, that break should be controllable perhaps in the section styles option with an “offset” from section beginning/end?
and in case of a section jog
The reason for this to make drawings readable and not have amess of rougue section lines, whilst still showing all the major section locations in plan.
Thank you as always.
L
