Feature request - information window
In Alias, if I want to know if two CPs are coincident, or to find out what surface type was used to create a surface, to see an object’s transformations, or to enter co-ordinates numerically, there’s a nifty information window that allows the user to see/do the aforementioned, and more. It would be very handy if this were to be implemented in Rhino also.
Hi, @Lagom. Can you provide a screenshot of what this info window looks like and a sketch of how you’d like it to be implemented in Rhino?
It seems like you could get some of this info by selecting your object(s) and referring to the Properties panel and/or using the BoxEdit command.
… there is also
_what (for users)
and
_list (for developers)
both will output a lot of info (not editable)
Hi @stevefuchs, here you go. Information Window. Object Lister. Diagnostic Shading. Control Panel. They are always active, shown or hidden with a hotkey or marking menu.
Sure, but it’s rather tedious. You usually want information about selected points, curves, surfaces, locators, etc. at any time, and you also want to be able to change a curve’s or surface’s properties on the fly. Rhino has all the information available “under the hood”, so it should be easy to make it available to the user in a simple fashion.
See the Control Panel, for example. When you’re collaborating on a project, you can see by the surface’s name which tool was used to build it; so useful.
@Lagom, this sounds ripe for a RhinoAI command exploration. Have you experimented with the AI panel, yet?
No, I don’t know about the AI panel; is that something available in version 8 macOS? If it is, how could the AI panel provide Alias or Catia like information/tools as shown above?
Here’s a video on how to setup & use the RhinoAI panel. We just released the video yesterday. https://www.youtube.com/watch?v=_8wtH8U99kc
My thought here is you could create a customized version of the BoxEdit command with any additional information you want, especially since you said the information is already available just not in a convenient place.
I think it’s way over my head to add all that Alias functionality to the BoxEdit tab. I mean, how even to get started with the most simple things - listing selected points and their co-ordinates, the type of surface, changing the U and V degree of a curve or surface on the fly?
I think it’s a healthy exercise to define what you are asking for, so we know what you are asking for. If you can define it in words, you can ask RhinoAI to do a few iterations as a proof-of-concept.
