When you scale an object to a specific size using the Gumball, while the origin is centered on the object, you have to type half of your target measurement, and not the measurement itself. For example, to end up with something 4 mm wide, you type “2mm”.
This works, but it means every scale operation requires a mental calculation before typing anything or writing [full measurement]/2mm, which isn’t intuitive, and I often forget, meaning I have to undo and retry. In fields like jewellery design where you are constantly scaling to precise known sizes, this adds up quickly.
The Idea
A simple toggle in the Gumball settings that lets you type the full measurement you actually want, and Rhino handles the halving for you behind the scenes.
To make it obvious which mode you are in, the square scale handles could be shown rotated 45 degrees (as diamonds) whenever the setting is on, much like the new snappy/smooth menu handle in Rhino 9. No new buttons or panels needed. Just an extra menu line and a visual hint that tells you at a glance that what you type is what you get.
Why It Would Help
Real-world dimensions are always described as full measurements. A ring shank is 2.4 mm wide, not “1.2 mm from its center.” The current behavior forces you to translate every measurement before you use it, which is a small but constant interruption to the workflow.
The Gumball is great. It’s faster than any alternative. BoxEdit, Scale1D, etc. all take more steps to get to the same result. But this is the one thing that bugs me every time. This feature would have no negative impact to the Gumball while matching the way designers actually think about dimensions.
Ah, I hadn’t seen this thread in my search, probably because “Gumball” wasn’t in the title. Your note that you “always seem to forget the first time”, just like me, really drives the point home for me: the current approach just isn’t that intuitive.
I do know about the Box Edit panel, and glad it works for you! My issue is that I use a number of panels open regularly and can’t keep them all on screen, so it tends to get hidden behind a tab. When that happens, Gumballs current functionality becomes the more practical option again.
