miano
(Miano)
July 23, 2021, 4:27pm
1
I wish there were some way to find all usages of a specific font that are visible in a layout.
I also wish the zoom selected would work in a layout.
I am getting fonts embedded in a large document that should not be there coming from embedded Rhino PDFs.
pascal
(Pascal Golay)
July 23, 2021, 4:34pm
2
Hello- SelFontUse may help here.
miano
(Miano)
July 23, 2021, 4:37pm
3
I am using SelFontUse but, in the layouts, it is apparently finding hidden instances of the font.
pascal
(Pascal Golay)
July 23, 2021, 5:22pm
4
I am not able to repeat that here so far.
miano
(Miano)
July 23, 2021, 7:17pm
5
If I
Create a layer X and have it visible
Put text in it (Say Times New Roman)
Create a Layout Y
In Y, hide X
SetFontUse Times New Roman
It selects the text, even though it is hidden on Y
miano
(Miano)
July 23, 2021, 7:56pm
6
I was just working on a large file where CAMBRIA was showing up in SelFontUse even though I had never used Cambria. (Uploaded to support)
When I did SelFontUSE CAMBRIA two text strings were selected. Both were in styles using CENTURY SCHOOLBOOK (with no option to reset to the style).
So I changed the styles for both (swapping) and when I selected the text, the object inspector said CENTURY SCHOOLBOOK.
Then I did SetlFontUse and Cambria was back. I selected and the same two boxes were selected and said Cambria.
I deleted one of the text boxes and created another. Using Century Schoolbook. SelFontUse Cambria selected that one.
If I print Layout Page 2, the resulting PDF says there is a text with Century Schoolbook but I sure cannot find that in the layout.
I see a lot of weird stuff with styles.
miano
(Miano)
July 23, 2021, 8:16pm
7
Problem Style.3dm.zip (18.0 KB)
Here is a simple example that shows the problem on my system at least.
The text box “DECONTAMIN RM” shows up at Cambria when selected.
If I change the style to ROOM NAMES then back to ROOM NAMES SMALL the font shows up at Century Schoolbook.
Now when I select the text box, it says CENTURY SCHOOLBOOK.
But then do SELFONTUSE CAMBRIA
and the same text box says CAMBRIA again.
miano
(Miano)
July 23, 2021, 8:25pm
8
Here is an every simpler one I found in another file.
Problem Font 2.3dm.zip (24.6 KB)
There are two text boxes in Century Schoolbook.
But do SelFontUSE CAMBRIA and both are selected.
pascal
(Pascal Golay)
July 23, 2021, 9:04pm
9
Got that, thanks.
RH-65077 SelFontUse: finds hidden text
