Often, the angle of surfaces along their shared boundary varies considerably, see below. For formal aesthetic reasons, in most cases, a chordal fillet should be used. FilletEdge has a chordal fillet option, so FilletSrf should have that feature, too.
You may achieve this by changing the Railtype in Filletedge from Rollingball to distbetweenrail)
Did you already tried?
Help Filletedge (link correct now)
This is a feature request regarding FilletSrf for those who use Rhino for NURBS surface modelling ; )
listed as RH-74756 Wish: FilletSrf Distance Between Rails Option
oops.
You’re right, yesterday it was late from my tablet…
Now, I’m more awake, and I can agree with you that the FilletSrf need the same options as FilletEdge.
Adding more the DistBetweenRails option need more love in general. Is one of my preferred choice but normally doesn’t fully works. @Gijs the v9 has taken care of this part as well?
Dear @Lagom you can use _variablefilletsrf
it has the options.
Just do not vary ihe radius.
Surfaces must intersect/share an edge.
Hi Tom, that’s more of a stopgap solution in my opinion. I think FilletSrf needs a chordal option, just like “other software” features since like forever, see below. Also, the great thing about FilletSrf is that you don’t need a shared edge, meaning you can always build surfaces to the possible minimum, not inheriting the parameterisation of the neighbour surface, even with gaps, as in that thing below, as you’d do in automotive - and then you just fillet that thing. A fillet has nothing to do with “edges”; fillets are surfaces between other surfaces, as Jim explained rather well on this forum many times.
@Tom_P you’re right but, probably you know it already, the (new) FilletSrf uses a different algorithm (Arc, Deformable, G2) so it doesn’t give the same control of the VariableFilletSrf.
I’ve to agree with @Lagom asking to add this option to the FilletSrf aslo.
…and looking forward to V9 I can’t imagine how powerfull it could become in addition to the tangent selection.
