Feature request - EdgeContinuity between surface boundary and curve
Would be great if one could evaluate that, too. After rebuilding a surface, a boundary may no longer be G0 with the underlying curve. Matching a surface boundary G0 to a curve works.
could you post an example that shows this in practice? I’ll get it written up but some clarity of the details would be helpful so I make sire to get your needs documented correctly.
After building surfaces from curves that are G2, and then matching them at A, one can no longer be certain that the surfaces are G0 to the curves they were built from. Often one can see they are not, if one zooms in far enough. It would be very useful if one could test for G0 between a surface boundary and the boundary curve, not only between surfaces, like in Alias or Catia. Hope that explains it.
You could use CrvDeviation to analyse the edge and curve but I suspect you want something live/permanent in the viewport?
Yep.
