should select all faces.
Thanks
ctrl+shift and lasso select and then extract will split that into its own part.
Thank you @theoutside for explaining this. I believe it should be easier and more intuitive though. As in any other program.
Hi Hannes -
ExtractSrf
works on SubD objects.
fwiw there is a split at edge loop too… not what you need here, but good to know if you did not.
Another tool to use in that case is Explode
, which will separate all the disjoint parts of the SubD into individual SubD objects (one SubD per connected component).
