Feature request - copy all errors C# / Code editors
Is there a way to copy all error from the ballon or within the code editor? Seem to only support line by line, or am I missing something? Helps with debugging with ChatGPT
Might be useful, but you should not favour ChatGPT but MSDN instead. Usually the error messages are on point. If you search for the message you often get a good example. It is helpful to understand the naming and why it is a problem. ChatGPT might provide you a false answer, whereas Microsoft documentation is usually correct (maybe outdated or too new). You might also start to learn a bit C# within a console application first to prevent doing the most obvious issues. GH is not a good place to learn C#.
