FEATURE REQUEST clipping plane name/saved view name/detail name sync
It would be great if when you create a clipping plane using “create clipping section” the names of the clipping plane and the saved view and the detail all synced up. It works this way the first time during creation of the clipping section but if you try and change the clipping plane name or copy and paste and then change the name nothing updates.
The NamedView name does sync, but you have to run UpdateClippingDrawings command or when the clipping plane is moved). I can see that the title in the detail does not update what named view it is referencing. Added a request here…
Loving how everything else is working so far!
