Feature Request/Bug SubD
  1. The various options on the QuadMesh command do not remain in place. The have to be reset each time you use it.
  2. If you create SubD surfaces with corners, join them, and explode the resulting subd surfaces do not have corners.
Hello - on Join, what does the command line say about joining SubDs?
The options are
Join Disjoint Meshes which I leave at the default of YES
SubD Joined Edges which I change to CREASE
