Hi
Really like VisualArq, very promising. To enable a more prfessional workflow I suggest following additions:
Possibility to choose multiple VA-objects and change properties, now it is only first
object that takes a change in a multiple selection array. -
Column styles, essential that different preset lengths can be added to a style under
sizes tab same way as width and height. This is a must for rational work with
columns. -
Tables should be possible to list both colmns and beams as per users choice. For a
wooden frame house a a dimension 45x145 is used as both columns and beams, and
you typically want a schedule for all lengths of a specific dimension in a
project. -
Possibility to trim beam and colmn ends (both vertically and horisontally at same time).
Typically needed where a beam parallell to a roof joins a wall. -
Possibility to select VA objects by style and material.
BR Patrik
Just take into account that columns don’t have “length” like beams, but “height”.
