I humbly request that when CheckNewObjects is enabled that it not give a warning with ExtractBadObjects.
Such a duplicative warning is redundant and superfluous.
Hello - I do not know if that is possible, the way things are set up - the warning pops up when a new invalid object is added to the document - when you extract a surface from a bad object, two new objects are added - and one removed - so you get this if one or both is bad. Better to fix the object.
