This is a feature I requested a while ago via support chat (RH-64892) but I never posted it here.
When you have a model that uses many clipping planes assigned to many detail views in many different layouts it can be really hard to keep track of it all - to say it’s tedious is an understatement. I came up with a UI that would make life a hell of a lot easier…see below.
This is the current UI for assigning clipping planes to details views
BTW…
Next few weeks, Rhino 8 WIP will have a new commandSelClippingPlaneInViewport command.
It selects clipping planes that are clipping the currently active viewport.
Works in model views and active detail views.
So if you test Rhino 8 WIP, next weeks April 26 or later build, you can try out this command.
Yes you have logged most of my requests/concerns over the last year or so! I decided to make posts on the forum about everything so I could better keep track of communication about it and see if anyone else would chime in. Thanks for all your efforts!
