Feature request - Add 'Copy' option to Rotate3D
Hello @mcneel
Would it be possible to add a ‘Copy’ option to the Rotate3D command? Similar to the option given with the standard Rotate command:
Thanks,
Dan
if you press ALT once, while rotating, you can copy
Diego,
Thanks for the reply, but I realized that the copy option is already there, you just need to pick the rotation axis first before the option becomes available…
Thanks,
Dan
