Viterkim
(Viktor)
August 24, 2026, 8:49am
1
Without playing repetitive strain injury simulator, it would be very convenient if we could have default behaviour of dragging (set via an advanced flag or whatever) default to doing a box selection, NOT just when out in empty space.
2 examples:
1
case like this, say we put the cursor on the square and want to drag out
well tough luck, we just dragged it, and i mean in all cases i would have enabled the gumball here to do a drag, or ran the move command.
2
with drag selected objects only we get this behaviour (so not what i would like)
we don’t have anything selected, we pick and area and start dragging but oops
it just only picks the first square, it does still not make a box of a drag selection.
and playing around with these things, they don’t fix the issue they just make it ‘drag it later’
And yes, you can hold down alt, that is very annoying if you want it to be the default behaviour for comfort/RSI long term.
And i know it has been discussed in other threads, but i think it would be much appreciated if there just was a toggle/advanced setting to just always make box selection a thing.
Hey is there a way to create a box selection when the mouse starts overtop of an existing object?
For example, imagine the viewport was inside a house, and I want to box select a chair, table, and rug inside that house. But if I try to box select, the house in the background will be immediately dragged. If I turn on the option “drag only selected”, then when I start the box select, the house is selected immediately and the box select doesn’t happen.
The only way I know of right now to get a su…
When working on architectural drawings with layers of hatches or bunch of lines I often need to drag a selection, but this can be really difficult or close to impossible with “normal” RMB or LMB drag.
So please add a “click to select one, and drag to select multiple” option.
Having to use “SelCrossing” and “SelWindow” does the trick, but it would make a lot of sense to add this as a feature IF “drag selected only” is turned on as a mouse feature.
And please add it to Rhino 5 so I don’t have t…
Hey, has any one figured out a way to disable the click and drag function. I am aware of the ability to set it to only drag selected objects, but I don’t find that always helps. For example when you are trying to select some object using a selection box and there are objects behind the ones you want to select. the first click simply selects the object behind, and the selection box does not appear. I find the click to drag function really annoying and not useful to anyone other than people doing …
Would it be possible to disable the drag of objects entirely?
As far as I know, now it’s only possible to check the option ‘Drag selected objects only’. That’s already something. But I would like the option to disable drag completely. In my workflow I never drag any objects and always use the move command. I only occasionally drag objects by accident which leads to inacurate models.
Is it an option to integrate this functionality?
I use shift and alt a lot to toggle between states. Holding shift to toggle ortho and holding alt to toggle osnaps.
Another handy trick that has dropped off the last few updates is holding alt select a small object in front of a large object. Say the screen is filled with a large object, with a few small objects in front of it. A standard marquee will select and drag the large object. But holding down alt while dragging the marquee used to disable the select, while being able to select objects …
This has been added as a request here - RH-98495
