Hello Community,
I always get shading problems when using RhinoCommon Brep.CapPlanerHoles method, no matter what kind of geometry I have:
I created a Rectangle3d, made the boundary surface end extruded, and then capped it;
extruded a closed curve using Surface.CreateExtrusin method, then capped;
used Sweep1 along a curve ( Brep.CreateFromSweep), then capped.
In all cases, resulting geometries are clear before capping.
After capping I am getting ugly, jagged shading(however, the geometries look normal).
Can anyone, please, advise me what is the cause of this or could you give me some hints on how it is possible to resolve this issue?
I have read @Helvetosaur’s post (Surface.CreateExtrusion) and Menno Deij’s answer but I still can not find out …
Thanks.
It’s most likely the same problem, the rectangle sweep is not split at the kinks and the resulting display mesh is bad - the Rhino mesher does not like kinked single surfaces.
Just like @Helvetosaur says, I never extrude joined curves (like Rectangle3d). I have always gotten better results by exploding the curve, extruding and then joining afterwards.
Hello everyone, thank you for your replies. @Helvetosaur it makes sense what you said, but I think there must be some method that addresses the issue decently since Grasshopper native components handle similar situations very well. @Ashley_Cichocki do you convert the curves (in this case Rectangle3d) to PolyCurve?
@Ashley_Cichocki,
I’m using C#, @adel.albloushi gave me a nice solution, and it worked well, but the issue was that I couldn’t use the same method for the rectangle with no fillets because then I could not convert Rectangle3d to PolyCurve( which has the method “Explode”). Your suggestion “DuplicateSegments” worked quite well for me.
Overall, the process looks a bit tricky but it works. At least now I have a clue how things are going… ))
Thank you again,
Hello @Ashley_Cichocki, sorry to bother you again with my question. How do we behave when we loft curves with different segments? In this case loft between a Triangle and a Pentagon? GH native loft component splits triangle edges so that its segment numbers coincide with pentagon segments. Can you give me a hint, please?
Hello all,
Thank you @Ashley_Cichocki,
Dale, @dale you saved my day Splitting kinky faces worked well. This was a solution for the lofting issue(faulty shading). Unfortunately, I can’t mark two solutions here at the same time.
