Faulty grasshopper in RiR
I have a faulty in RiR install for a few versions of Revit.
The later revit versions 2026, 2025 were ok.
Example of Revit 2022 gh problem.
Less icons in ribbon and empty box in search function
Rhino Command History:
Speckle does not currently support Rhino.Inside
Command: _Grasshopper
An error occured during GHA assembly loading:
Path: C:...\AppData\Roaming\Grasshopper\Libraries\coretoolboxgrasshopper.gha
Exception System.IO.FileLoadException:
Message: Could not load file or assembly ‘file:///C:...\AppData\Roaming\Grasshopper\Libraries\coretoolboxgrasshopper.gha’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception System.NotSupportedException:
Message: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See <loadFromRemoteSources> Element | Microsoft Learn for more information.
Revit 2022 addins
RiR Version
Rhino Version
Anyone know of a fix?
Thanks
are you up to date in this plugin? it’s an .net error (Revit 2022 runs in .netframework 4.8)
How to update? Or check I am up to date.
Windows says file was last modified 18/05/2026
Is the issue still there if you remove the plugin? It sounds like its incompatible (built for newer Revit versions)
If I remove the plugin will it impact functionality for Revit 2026 where RiR works fine?
I am not having a conflict with this version which has a different build date.
Is it TTToolbox that is coretoolboxgrasshopper.gha?
That is in my grasshopper for Revit 2026 even though I cannot remember installing the package.
However, TTToolbox was not loaded for Revit 2022.
But you gave me an idea to uninstall packages. I did a test and removed a plugin - Roadrunner - and that seems to have fixed my Revit 2022 gh.
Thanks Japhy
