I’m trying to model finger jointed designs in Rhino by following this tutorial (I’m running Mac, so no Grasshopper): http://dclabs.wikispaces.asu.edu/file/detail/Finger%20Joints.3dm from http://dclabs.wikispaces.asu.edu/Rhino+Resources (Instructions are included in the file’s
notes).
Apparently a few things changed in Rhino since this tutorial was made. In particular, I was wondering if there was a faster (and more automatable) method than mine to create a hollow solid.
My current process:
- Create a box (As extrusion or polysurface, doesn’t seem to affect the result)
- Explode faces of the box (If I do not explode the box, Rhino cannot create a solid from the offsetted polysurface)
- OffsetSrf and flip offsetting direction (As I need to offset inward to avoid edges-gap) for each side (As I had to explode the polysurface). That’s the time consumming-part, especially for more complex surfaces than boxes.
Is there a way to go from a closed polysurface such as a box to an offsetted solid without having to manually orient each face?
I know that’s a minor detail but since I was looking to script the thing afterward, the less manual operations the better
Xavier
