Farthest and shortest distance in a given geometry
Hello everybody,
I was wondering if there is a way to figure out the shortest and farthest distance within any given Brep. I want to use the ratio of this as a way of describing the complexity.
Would be super grateful for any help! Thanks :slight_smile:
If you share a Rhino file with some BREP examples, we can take a look.
Yes, of course. Here a few examples.
Mixed Geometries.3dm (882.9 KB)
You might need to be a bit more explicit about what those terms mean. But if they refer to analysing thickness, one can implement the native RhinoCommon method in a scripting component:
Also welcome on board :slight_smile:
So my idea is to find the smallest axis and the longest axis in the geometry (similar to calculating the eccentricity of an ellipse). Maybe one can better understand what I mean in the picture. The red arrow being the longest axis and the green arrow the shortest. Thanks for the help so far :slight_smile:
But that green arrow goes outside the brep !? And it’s not the shortest “axis” anyway, a vertical line would be shorter.
Obvious, right? So how come you had to be asked to post geometry? And when you did, it’s an R8 file that can’t be opened in R7.
XSXS
And longest distance as well - would surely run the length of the part (or diagonally etc). Longest and Shortest need to be much more explicitly defined before building this in GH. Unless all they want is the max/min distance in a particular cross-section. I dunno.
Thanks for the replies. Sorry I was a bit unclear on what I meant. An easier example would be this geometry with both axis going through the centre of the geometry (incorrectly drawn on my other picture sorry about that). Then the idea is that one axis finds the shortest distance within the geometry intersecting with the centre of the geometry. The same for the other axis only that it searches for the longest distance.
Geometry Example.3dm (90.8 KB)
How are you defining center? Volume centroid? Area centriod? Center of the bounding box with a specified orientation? Somthing else???
Volume centroid
sorry, I’m a bit slow :slight_smile: do you mean that this measurement should be done on the XY plane passing through the Volume Centroid:
…or also on Z direction?
I thought you could read minds? :rofl:
Thanks for taking a look:) Also in the Z direction
Create lines from your volume center and where it intersects the part take a measurement.
intersect.gh (20.3 KB)
