I’m trying to save an attribute to Object.Attributes.UserData. The data is saved during the session, but when reloading the .3dm file it is not. (The color change to Attributes.ObjectColor is saved, but the custom dat added to Attributes.UserData is not found after reloading)
I appreciate any input on what I might be missing or doing wrong here. I tried adding a GUID to the custom UserData class as per this thread, but it did not solve the problem.
Below is the code snippet that should save the data. The code is inspired by this GitHub example.
// Mark selected objects with the selected surface type
foreach (var objRef in goObject.Objects())
var obj = objRef.Object();
if (obj != null)
var userData = obj.Attributes.UserData.Find(typeof(SurfaceTypeUserData)) as SurfaceTypeUserData;
if (userData != null)
RhinoApp.WriteLine("Current SurfaceType is: {0}", userData.SurfaceType);
// Set the selected surface type
userData = new SurfaceTypeUserData
SurfaceType = selectedSurfaceType
// Apply the color to the object's display attributes
obj.Attributes.ObjectColor = selectedColor;
obj.Attributes.ColorSource = ObjectColorSource.ColorFromObject;
obj.Attributes.UserData.Add(userData);
obj.CommitChanges();
doc.Views.Redraw();
return Result.Success;
And here is the code for the custom UserData type that I’m attempting to save:
using Formulight.DataObjects;
using Rhino.DocObjects.Custom;
using Rhino.FileIO;
using System;
[Serializable]
public class SurfaceTypeUserData : UserData
public SurfaceType SurfaceType { get; set; }
public override string Description => "SurfaceType User Data";
public override bool ShouldWrite => true;
protected override void OnDuplicate(UserData source)
if (source is SurfaceTypeUserData src)
SurfaceType = src.SurfaceType;
protected override bool Read(BinaryArchiveReader archive)
SurfaceType = (SurfaceType)archive.ReadInt();
return true;
protected override bool Write(BinaryArchiveWriter archive)
archive.WriteInt((int)SurfaceType);
return true;
